[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.null/null.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c main.c null.c )| 0 monsters | 2 warnings
Wed Aug 23 07:40:17 EDT 2006
Hello markus,
ANALYSIS
raster/r.null/null.c functions
main (Begins at: 13 Ends at: 214)
Complexity:   |      16 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     202 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
parse_vallist (Begins at: 216 Ends at: 249)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
parse_d_mask_rule (Begins at: 252 Ends at: 285)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
process (Begins at: 288 Ends at: 330)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
doit (Begins at: 333 Ends at: 392)
CalledNBR:    |      25 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  parse_vallist
In raster/r.null/null.c clones of  parse_vallist are:
	display/d.rast/main.c  parse_vallist
	display/d.rast/main.c  parse_catlist
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
