[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.out.dxf/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:27 EDT 2006
Hello markus,
ANALYSIS
vector/v.out.dxf/main.c functions
main (Begins at: 35 Ends at: 91)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 57 | | OK |
metrics are OK
do_limits (Begins at: 93 Ends at: 110)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 18 | | OK |
metrics are OK
make_layername (Begins at: 112 Ends at: 132)
Complexity: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 21 | | OK |
metrics are OK
add_plines (Begins at: 134 Ends at: 191)
Complexity: | 6 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 58 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
