[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.surf.idw/main.c |no clones | 0 monsters | 3 warnings
Wed Aug 23 07:40:21 EDT 2006
Hello markus,
ANALYSIS
raster/r.surf.idw/main.c functions
main (Begins at: 28 Ends at: 153)
Complexity:   |      12 |       |      OK |
CalledNBR:    |      50 |     * |         |
LOC:          |     126 |     * |         |
metrics are OK
lookup_and_function_ptrs (Begins at: 155 Ends at: 188)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
interpolate (Begins at: 191 Ends at: 279)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      10 |       |      OK |
LOC:          |      89 |       |      OK |
at least 1 values are close to an outlier please consider revising code
make_neighbors_list (Begins at: 281 Ends at: 344)
Complexity:   |      11 |       |      OK |
LOC:          |      64 |       |      OK |
search (Begins at: 349 Ends at: 395)
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |       8 |       |      OK |
LOC:          |      47 |       |      OK |
exhaust (Begins at: 398 Ends at: 424)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
offset_distance (Begins at: 426 Ends at: 429)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
completed_row (Begins at: 435 Ends at: 438)
LOC:          |       4 |       |      OK |
metrics are OK
next_row (Begins at: 441 Ends at: 456)
Complexity:   |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
first_west (Begins at: 464 Ends at: 478)
Complexity:   |       3 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
find_neighbors (Begins at: 486 Ends at: 514)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
exhaust_search (Begins at: 521 Ends at: 543)
LOC:          |      23 |       |      OK |
metrics are OK
triangulate (Begins at: 550 Ends at: 558)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
add_neighbor (Begins at: 561 Ends at: 576)
LOC:          |      16 |       |      OK |
metrics are OK
replace_neighbor (Begins at: 579 Ends at: 601)
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
sort_neighbors (Begins at: 604 Ends at: 617)
LOC:          |      14 |       |      OK |
metrics are OK
free_row_lists (Begins at: 621 Ends at: 638)
LOC:          |      18 |       |      OK |
metrics are OK
row_lists (Begins at: 641 Ends at: 701)
LOC:          |      61 |       |      OK |
metrics are OK
lookup_tables (Begins at: 708 Ends at: 726)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
