[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.lrs/v.lrs.segment/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c main.c null.c main.c main.c main.c main.c main.c main.c main.c )| 1 monsters | 0 warnings
Wed Aug 23 07:40:25 EDT 2006
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.segment/main.c functions
main (Begins at: 40 Ends at: 281)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      84 |   *** | MONSTER |
LOC:          |     242 |    ** | Warning |
1 metric are OUT OF RANGE!
find_line (Begins at: 286 Ends at: 303)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  find_line
In vector/v.lrs/v.lrs.segment/main.c clones of  find_line are:
	vector/v.segment/main.c  find_line
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
