[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.cats/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:15 EDT 2006
Hello markus,
ANALYSIS
raster/r.cats/main.c functions
main (Begins at: 12 Ends at: 132)
Complexity: | 16 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 45 | * | |
LOC: | 121 | * | |
metrics are OK
print_label (Begins at: 135 Ends at: 143)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 9 | | OK |
metrics are OK
print_d_label (Begins at: 146 Ends at: 158)
CalledNBR: | 5 | | OK |
LOC: | 13 | | OK |
metrics are OK
scan_cats (Begins at: 161 Ends at: 175)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 15 | | OK |
metrics are OK
scan_vals (Begins at: 178 Ends at: 185)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 8 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
