[GRASS-QA] GRASS QA: markus | ./grass6/display/d.rast/main.c |4
	clones ( main.c main.c main.c )| 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Wed Aug 23 07:40:08 EDT 2006
Hello markus,
ANALYSIS
display/d.rast/main.c functions
main (Begins at: 12 Ends at: 119)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |     108 |       |      OK |
metrics are OK
parse_catlist (Begins at: 121 Ends at: 154)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
parse_vallist (Begins at: 156 Ends at: 189)
LOC:          |      34 |       |      OK |
metrics are OK
parse_mask_rule (Begins at: 192 Ends at: 222)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
parse_d_mask_rule (Begins at: 225 Ends at: 255)
LOC:          |      31 |       |      OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
  parse_d_mask_rule  parse_mask_rule  parse_vallist  parse_catlist
In display/d.rast/main.c clones of  parse_catlist are:
	raster/r.null/null.c  parse_vallist
	display/d.rast/main.c  parse_vallist
In display/d.rast/main.c clones of  parse_vallist are:
	display/d.rast/main.c  parse_catlist
In display/d.rast/main.c clones of  parse_mask_rule are:
	display/d.rast/main.c  parse_d_mask_rule
In display/d.rast/main.c clones of  parse_d_mask_rule are:
	display/d.rast/main.c  parse_mask_rule
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
