[GRASS-QA] GRASS QA: markus | ./grass6/display/d.paint.labels/main.c |no clones | 0 monsters | 1 warnings
Wed Aug 23 07:40:08 EDT 2006
Hello markus,
ANALYSIS
display/d.paint.labels/main.c functions
main (Begins at: 9 Ends at: 130)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      63 |    ** | Warning |
LOC:          |     122 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
