[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.cost/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c )| 3 monsters | 0 warnings
Wed Aug 23 07:40:16 EDT 2006
Hello markus,
ANALYSIS
raster/r.cost/main.c functions
main (Begins at: 51 Ends at: 1035)
Complexity:   |     148 |   *** | MONSTER |
CalledNBR:    |     288 |   *** | MONSTER |
LOC:          |     985 |   *** | MONSTER |
3 metric are OUT OF RANGE!
process_answers (Begins at: 1038 Ends at: 1086)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
time_to_stop (Begins at: 1088 Ends at: 1108)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  time_to_stop
In raster/r.cost/main.c clones of  time_to_stop are:
	raster/r.walk/main.c  time_to_stop
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
