[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.select/main.c |no clones | 2 monsters | 0 warnings
Wed Aug 23 08:27:14 EDT 2006
Hello markus,
ANALYSIS
vector/v.select/main.c functions
add_aarea (Begins at: 26 Ends at: 54)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
line_overlap_area (Begins at: 57 Ends at: 102)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
main (Begins at: 105 Ends at: 487)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |     116 |   *** | MONSTER |
LOC:          |     383 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
