[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.gensigset/main.c |no clones | 0 monsters | 0 warnings
Wed Aug 23 08:54:35 EDT 2006
Hello markus,
ANALYSIS
imagery/i.gensigset/main.c functions
main (Begins at: 9 Ends at: 41)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
