[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/v.lidar.correction/correction.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Aug 24 18:01:30 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.lidar.correction/correction.c functions
P_Sparse_Correction (Begins at: 11 Ends at: 155)
Complexity: | 25 | * | |
ParamNBR: | 19 | *** | MONSTER |
CalledNBR: | 62 | ** | Warning |
LOC: | 145 | * | |
1 metric are OUT OF RANGE!
correction (Begins at: 158 Ends at: 173)
Complexity: | 5 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 2 | | OK |
LOC: | 16 | | OK |
metrics are OK
Select_Correction (Begins at: 175 Ends at: 204)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 30 | | OK |
metrics are OK
Insert_Correction (Begins at: 206 Ends at: 218)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
UpDate_Correction (Begins at: 220 Ends at: 230)
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
P_Read_Vector_Correction (Begins at: 233 Ends at: 297)
Complexity: | 6 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 65 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
