[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/lidarlib/raster.c |no clones | 2
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Aug 24 18:11:02 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/lidarlib/raster.c functions
P_Sparse_Points (Begins at: 15 Ends at: 174)
Complexity: | 19 | * | |
ParamNBR: | 18 | *** | MONSTER |
CalledNBR: | 70 | ** | Warning |
LOC: | 160 | * | |
1 metric are OUT OF RANGE!
P_Regular_Points (Begins at: 179 Ends at: 269)
Complexity: | 11 | | OK |
ParamNBR: | 14 | *** | MONSTER |
CalledNBR: | 7 | | OK |
LOC: | 91 | | OK |
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
