[GRASS-QA] GRASS QA: glynn | ./grass6/lib/form/open.c |no clones | 0 monsters | 0 warnings
Fri Aug 25 09:21:21 EDT 2006
Hello glynn,
ANALYSIS
lib/form/open.c functions
F_open (Begins at: 35 Ends at: 131)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      34 |     * |         |
LOC:          |      97 |       |      OK |
metrics are OK
F_clear (Begins at: 137 Ends at: 149)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
F_close (Begins at: 152 Ends at: 166)
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-25 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
