[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/loc_io.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 30 16:48:04 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/loc_io.c functions
LOC_init (Begins at: 22 Ends at: 56)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 35 | | OK |
metrics are OK
LOC_open_driver (Begins at: 58 Ends at: 106)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 49 | | OK |
metrics are OK
LOC__open_quiet (Begins at: 108 Ends at: 111)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
LOC_stabilize (Begins at: 113 Ends at: 118)
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
LOC_kill_driver (Begins at: 120 Ends at: 125)
LOC: | 6 | | OK |
metrics are OK
LOC_close_driver (Begins at: 127 Ends at: 134)
LOC: | 8 | | OK |
metrics are OK
LOC_release_driver (Begins at: 136 Ends at: 142)
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-30 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 252 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
