[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.digit/centre.c |no clones | 0 monsters | 0 warnings
Thu Aug 31 05:34:22 EDT 2006
Hello hamish,
ANALYSIS
vector/v.digit/centre.c functions
tool_centre (Begins at: 29 Ends at: 132)
Complexity:   |      25 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |     104 |       |      OK |
metrics are OK
update (Begins at: 135 Ends at: 148)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-31 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
