[GRASS-QA] GRASS QA: brad | ./grass6/lib/gmath/eigen.c |no clones |
0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:19 EST 2006
Hello brad,
ANALYSIS
lib/gmath/eigen.c functions
eigen (Begins at: 10 Ends at: 41)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 32 | | OK |
metrics are OK
egcmp (Begins at: 46 Ends at: 53)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
egvorder2 (Begins at: 56 Ends at: 95)
ParamNBR: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 40 | | OK |
metrics are OK
transpose2 (Begins at: 100 Ends at: 113)
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
