[GRASS-QA] GRASS QA: brad | ./grass6/lib/vask/V_call.c |no clones |
3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:20 EST 2006
Hello brad,
ANALYSIS
lib/vask/V_call.c functions
V_call (Begins at: 145 Ends at: 450)
Complexity: | 64 | *** | MONSTER |
ParamNBR: | 1 | | OK |
CalledNBR: | 87 | *** | MONSTER |
LOC: | 306 | *** | MONSTER |
3 metric are OUT OF RANGE!
V_intrpt_ok (Begins at: 452 Ends at: 469)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
V_intrpt_msg (Begins at: 471 Ends at: 476)
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
fmt (Begins at: 479 Ends at: 495)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 17 | | OK |
metrics are OK
centered (Begins at: 497 Ends at: 508)
Complexity: | 2 | | OK |
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
