[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.resamp.rst/main.c
|1 clones ( color_get.c dalloc.c dalloc.c main.c main.c
main.c parser.c main.c )| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:23 EST 2006
Hello hamish,
ANALYSIS
raster/r.resamp.rst/main.c functions
main (Begins at: 132 Ends at: 593)
Complexity: | 64 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 181 | *** | MONSTER |
LOC: | 462 | *** | MONSTER |
3 metric are OUT OF RANGE!
create_temp_files (Begins at: 595 Ends at: 681)
Complexity: | 20 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 50 | * | |
LOC: | 87 | | OK |
metrics are OK
clean_fatal_error (Begins at: 683 Ends at: 710)
Complexity: | 7 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 28 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
clean_fatal_error
In raster/r.resamp.rst/main.c clones of clean_fatal_error are:
vector/v.surf.rst/main.c clean_fatal_error
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
