[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.mfilter/getfilt.c
|no clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:25 EST 2006
Hello jachym,
ANALYSIS
raster/r.mfilter/getfilt.c functions
get_filter (Begins at: 7 Ends at: 185)
Complexity: | 27 | ** | Warning |
ParamNBR: | 3 | | OK |
CalledNBR: | 31 | | OK |
LOC: | 179 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
