[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.report/parse.c |no clones | 0 monsters | 1 warnings
Sat Dec 9 13:54:28 EST 2006
Hello jachym,
ANALYSIS
raster/r.report/parse.c functions
parse_command_line (Begins at: 8 Ends at: 206)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      56 |     * |         |
LOC:          |     199 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
parse_units (Begins at: 208 Ends at: 243)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
parse_layer (Begins at: 245 Ends at: 290)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
match (Begins at: 292 Ends at: 299)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
