[GRASS-QA] GRASS QA: jachym | ./grass6/raster/simwe/simlib/input.c
|no clones | 3 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:32 EST 2006
Hello jachym,
ANALYSIS
raster/simwe/simlib/input.c functions
input_data (Begins at: 24 Ends at: 336)
Complexity: | 80 | *** | MONSTER |
ParamNBR: | 0 | | OK |
CalledNBR: | 114 | *** | MONSTER |
LOC: | 313 | *** | MONSTER |
3 metric are OUT OF RANGE!
grad_check (Begins at: 340 Ends at: 558)
Complexity: | 25 | * | |
CalledNBR: | 34 | | OK |
LOC: | 219 | ** | Warning |
at least 1 values are close to an outlier please consider revising code
amax1 (Begins at: 561 Ends at: 572)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
amin1 (Begins at: 575 Ends at: 586)
LOC: | 12 | | OK |
metrics are OK
min (Begins at: 589 Ends at: 602)
LOC: | 14 | | OK |
metrics are OK
max (Begins at: 604 Ends at: 615)
LOC: | 12 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
