[GRASS-QA] GRASS QA: markus |
./grass6/db/drivers/postgres/describe.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:33 EST 2006
Hello markus,
ANALYSIS
db/drivers/postgres/describe.c functions
db__driver_describe_table (Begins at: 7 Ends at: 39)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 33 | | OK |
metrics are OK
describe_table (Begins at: 42 Ends at: 154)
Complexity: | 9 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 113 | | OK |
metrics are OK
get_column_info (Begins at: 156 Ends at: 220)
Complexity: | 20 | * | |
ParamNBR: | 6 | * | |
CalledNBR: | 5 | | OK |
LOC: | 65 | | OK |
metrics are OK
get_gpg_type (Begins at: 223 Ends at: 232)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
