[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.to.vect/main.c |no clones | 1 monsters | 0 warnings
Sat Dec 9 13:54:32 EST 2006
Hello jachym,
ANALYSIS
raster/r.to.vect/main.c functions
main (Begins at: 19 Ends at: 254)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      99 |   *** | MONSTER |
LOC:          |     236 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
