[GRASS-QA] GRASS QA: jachym |
./grass6/raster/wildfire/r.spread/spread.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:33 EST 2006
Hello jachym,
ANALYSIS
raster/wildfire/r.spread/spread.c functions
spread (Begins at: 60 Ends at: 155)
Complexity: | 12 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 96 | | OK |
metrics are OK
cumulative (Begins at: 162 Ends at: 222)
Complexity: | 6 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 8 | | OK |
LOC: | 61 | | OK |
metrics are OK
update (Begins at: 229 Ends at: 259)
Complexity: | 9 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 4 | | OK |
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
