[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.statistics/o_skew.c |1 clones ( color_get.c dalloc.c dalloc.c main.c main.c main.c parser.c main.c main.c main.c count.c main.c main.c o_kurt.c o_skew.c )| 0 monsters | 0 warnings
Sat Dec 9 13:54:30 EST 2006
Hello jachym,
ANALYSIS
raster/r.statistics/o_skew.c functions
o_skew (Begins at: 14 Ends at: 93)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
skew (Begins at: 96 Ends at: 134)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  skew
In raster/r.statistics/o_skew.c clones of  skew are:
	raster/r.statistics/o_kurt.c  kurt
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
