[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/getgrid.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:34 EST 2006
Hello markus,
ANALYSIS
ps/ps.map/getgrid.c functions
getgrid (Begins at: 32 Ends at: 124)
Complexity: | 19 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 93 | | OK |
metrics are OK
getgeogrid (Begins at: 129 Ends at: 218)
Complexity: | 18 | * | |
CalledNBR: | 20 | | OK |
LOC: | 90 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
