[GRASS-QA] GRASS QA: martinl | ./grass6/display/d.vect/label.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:39 EST 2006
Hello martinl,
ANALYSIS
display/d.vect/label.c functions
label (Begins at: 8 Ends at: 151)
Complexity:   |      25 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      31 |       |      OK |
LOC:          |     144 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
