[GRASS-QA] GRASS QA: brad | ./grass6/lib/gis/is.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:18 EST 2006
Hello brad,
ANALYSIS
lib/gis/is.c functions
test_path_file (Begins at: 6 Ends at: 20)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 15 | | OK |
metrics are OK
G_is_gisbase (Begins at: 28 Ends at: 31)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
G_is_location (Begins at: 39 Ends at: 42)
LOC: | 4 | | OK |
metrics are OK
G_is_mapset (Begins at: 50 Ends at: 53)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
