[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/done_msg.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:21 EST 2006
Hello glynn,
ANALYSIS
lib/gis/done_msg.c functions
G_done_msg (Begins at: 4 Ends at: 9)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
