[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.surf.idw/main.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 13:54:31 EST 2006
Hello jachym,
ANALYSIS
raster/r.surf.idw/main.c functions
main (Begins at: 28 Ends at: 153)
Complexity: | 12 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 50 | * | |
LOC: | 126 | * | |
metrics are OK
lookup_and_function_ptrs (Begins at: 155 Ends at: 188)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 34 | | OK |
metrics are OK
interpolate (Begins at: 191 Ends at: 279)
Complexity: | 7 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 10 | | OK |
LOC: | 89 | | OK |
at least 1 values are close to an outlier please consider revising code
make_neighbors_list (Begins at: 281 Ends at: 344)
Complexity: | 11 | | OK |
LOC: | 64 | | OK |
search (Begins at: 349 Ends at: 395)
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 47 | | OK |
exhaust (Begins at: 398 Ends at: 424)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
offset_distance (Begins at: 426 Ends at: 429)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
completed_row (Begins at: 435 Ends at: 438)
LOC: | 4 | | OK |
metrics are OK
next_row (Begins at: 441 Ends at: 456)
Complexity: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
first_west (Begins at: 464 Ends at: 478)
Complexity: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
find_neighbors (Begins at: 486 Ends at: 514)
ParamNBR: | 6 | * | |
CalledNBR: | 3 | | OK |
LOC: | 29 | | OK |
metrics are OK
exhaust_search (Begins at: 521 Ends at: 543)
LOC: | 23 | | OK |
metrics are OK
triangulate (Begins at: 550 Ends at: 558)
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
add_neighbor (Begins at: 561 Ends at: 576)
LOC: | 16 | | OK |
metrics are OK
replace_neighbor (Begins at: 579 Ends at: 601)
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
sort_neighbors (Begins at: 604 Ends at: 617)
LOC: | 14 | | OK |
metrics are OK
free_row_lists (Begins at: 621 Ends at: 638)
LOC: | 18 | | OK |
metrics are OK
row_lists (Begins at: 641 Ends at: 701)
LOC: | 61 | | OK |
metrics are OK
lookup_tables (Begins at: 708 Ends at: 726)
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
