[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.mfilter/perform.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:25 EST 2006
Hello jachym,
ANALYSIS
raster/r.mfilter/perform.c functions
perform_filter (Begins at: 8 Ends at: 127)
Complexity:   |      20 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      38 |     * |         |
LOC:          |     120 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
