[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.out.ascii/b2a.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Dec 9 14:15:30 EST 2006
Hello hamish,
ANALYSIS
vector/v.out.ascii/b2a.c functions
bin_to_asc (Begins at: 5 Ends at: 166)
Complexity: | 28 | ** | Warning |
ParamNBR: | 6 | * | |
CalledNBR: | 44 | * | |
LOC: | 162 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-09 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
