[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.to.db/report.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Dec 11 13:03:01 EST 2006
Hello jachym,
ANALYSIS
vector/v.to.db/report.c functions
report (Begins at: 5 Ends at: 136)
Complexity: | 28 | ** | Warning |
ParamNBR: | 1 | | OK |
CalledNBR: | 32 | | OK |
LOC: | 132 | * | |
at least 1 values are close to an outlier please consider revising code
print_stat (Begins at: 139 Ends at: 151)
Complexity: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
