[GRASS-QA] GRASS QA: hamish | ./grass6/display/d.frame/frame.c |no clones | 0 monsters | 0 warnings
Tue Dec 12 03:36:17 EST 2006
Hello hamish,
ANALYSIS
display/d.frame/frame.c functions
main (Begins at: 24 Ends at: 167)
Complexity:   |      19 |     * |         |
CalledNBR:    |      50 |     * |         |
LOC:          |     144 |     * |         |
metrics are OK
check_at (Begins at: 170 Ends at: 185)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-12 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
