[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.out.vtk/main.c |3 clones ( write.c write.c g3dclose.c main.c )| 0 monsters | 2 warnings
Wed Dec 13 10:02:42 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.vtk/main.c functions
create_input_maps_struct (Begins at: 56 Ends at: 81)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
open_input_map (Begins at: 86 Ends at: 101)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
check_input_maps (Begins at: 107 Ends at: 182)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
open_write_rgb_maps (Begins at: 188 Ends at: 266)
Complexity:   |      19 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      20 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
open_write_vector_maps (Begins at: 271 Ends at: 349)
LOC:          |      79 |       |      OK |
metrics are OK
main (Begins at: 355 Ends at: 557)
Complexity:   |      24 |     * |         |
CalledNBR:    |      67 |    ** | Warning |
LOC:          |     203 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file has 3 potentially cloned functions:
  open_input_map  open_write_vector_maps  open_write_rgb_maps
In raster3d/r3.out.vtk/main.c clones of  open_write_vector_maps are:
	raster3d/r3.out.vtk/main.c  open_write_rgb_maps
In raster3d/r3.out.vtk/main.c clones of  open_write_rgb_maps are:
	raster3d/r3.out.vtk/main.c  open_write_vector_maps
In raster3d/r3.out.vtk/main.c clones of  open_input_map are:
	raster/r.to.rast3/main.c  open_input_raster_map
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
