[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.distance/distance.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 10:02:42 EST 2006
Hello markus,
ANALYSIS
raster/r.distance/distance.c functions
find_minimum_distance (Begins at: 27 Ends at: 75)
Complexity: | 6 | | OK |
ParamNBR: | 11 | *** | MONSTER |
CalledNBR: | 8 | | OK |
LOC: | 49 | | OK |
1 metric are OUT OF RANGE!
null_distance (Begins at: 77 Ends at: 163)
Complexity: | 12 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 27 | | OK |
LOC: | 87 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
