[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.out.vtk/main.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 10:02:44 EST 2006
Hello markus,
ANALYSIS
raster/r.out.vtk/main.c functions
check_input_maps (Begins at: 37 Ends at: 123)
Complexity: | 12 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 87 | | OK |
metrics are OK
main (Begins at: 129 Ends at: 386)
Complexity: | 27 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 73 | ** | Warning |
LOC: | 258 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
