[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.sun/main.c |no
clones | 3 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 10:02:45 EST 2006
Hello markus,
ANALYSIS
raster/r.sun/main.c functions
main (Begins at: 132 Ends at: 470)
Complexity: | 24 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 111 | *** | MONSTER |
LOC: | 339 | *** | MONSTER |
2 metric are OUT OF RANGE!
INPUT (Begins at: 473 Ends at: 692)
Complexity: | 45 | *** | MONSTER |
ParamNBR: | 1 | | OK |
CalledNBR: | 81 | ** | Warning |
LOC: | 220 | ** | Warning |
1 metric are OUT OF RANGE!
OUTGR (Begins at: 694 Ends at: 824)
Complexity: | 29 | ** | Warning |
CalledNBR: | 50 | * | |
LOC: | 131 | * | |
at least 1 values are close to an outlier please consider revising code
com_par_const (Begins at: 827 Ends at: 864)
Complexity: | 6 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 38 | | OK |
metrics are OK
com_par (Begins at: 867 Ends at: 938)
Complexity: | 8 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 72 | | OK |
metrics are OK
lumcline2 (Begins at: 942 Ends at: 980)
Complexity: | 7 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 39 | | OK |
metrics are OK
joules2 (Begins at: 982 Ends at: 1112)
Complexity: | 22 | * | |
CalledNBR: | 11 | | OK |
LOC: | 131 | * | |
metrics are OK
new_point (Begins at: 1117 Ends at: 1126)
Complexity: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 10 | | OK |
metrics are OK
where_is_point (Begins at: 1128 Ends at: 1153)
LOC: | 26 | | OK |
metrics are OK
cube (Begins at: 1155 Ends at: 1160)
LOC: | 6 | | OK |
metrics are OK
searching (Begins at: 1162 Ends at: 1188)
CalledNBR: | 3 | | OK |
LOC: | 27 | | OK |
metrics are OK
calculate (Begins at: 1194 Ends at: 1431)
CalledNBR: | 53 | * | |
LOC: | 238 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
com_sol_const (Begins at: 1433 Ends at: 1442)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
com_declin (Begins at: 1445 Ends at: 1455)
LOC: | 11 | | OK |
metrics are OK
brad (Begins at: 1457 Ends at: 1484)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 28 | | OK |
metrics are OK
drad (Begins at: 1486 Ends at: 1540)
LOC: | 55 | | OK |
metrics are OK
test (Begins at: 1542 Ends at: 1556)
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
