[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.fill.dir/tinf.c |1 clones ( write.c write.c g3dclose.c main.c raster.c tinf.c )| 0 monsters | 0 warnings
Wed Dec 13 10:02:43 EST 2006
Hello markus,
ANALYSIS
raster/r.fill.dir/tinf.c functions
set_func_pointers (Begins at: 13 Ends at: 72)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      60 |       |      OK |
metrics are OK
is_null_c (Begins at: 75 Ends at: 75)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
is_null_f (Begins at: 76 Ends at: 76)
LOC:          |       1 |       |      OK |
metrics are OK
is_null_d (Begins at: 77 Ends at: 77)
LOC:          |       1 |       |      OK |
metrics are OK
bpe_c (Begins at: 80 Ends at: 80)
ParamNBR:     |       0 |       |      OK |
LOC:          |       1 |       |      OK |
metrics are OK
bpe_f (Begins at: 81 Ends at: 81)
LOC:          |       1 |       |      OK |
metrics are OK
bpe_d (Begins at: 82 Ends at: 82)
LOC:          |       1 |       |      OK |
metrics are OK
get_min_c (Begins at: 85 Ends at: 92)
Complexity:   |       2 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
get_min_f (Begins at: 94 Ends at: 101)
LOC:          |       8 |       |      OK |
metrics are OK
get_min_d (Begins at: 103 Ends at: 110)
LOC:          |       8 |       |      OK |
metrics are OK
get_max_c (Begins at: 113 Ends at: 120)
LOC:          |       8 |       |      OK |
metrics are OK
get_max_f (Begins at: 122 Ends at: 129)
LOC:          |       8 |       |      OK |
metrics are OK
get_max_d (Begins at: 131 Ends at: 138)
LOC:          |       8 |       |      OK |
metrics are OK
get_row_c (Begins at: 141 Ends at: 144)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
get_row_f (Begins at: 146 Ends at: 149)
LOC:          |       4 |       |      OK |
metrics are OK
get_row_d (Begins at: 151 Ends at: 154)
LOC:          |       4 |       |      OK |
metrics are OK
put_row_c (Begins at: 157 Ends at: 160)
LOC:          |       4 |       |      OK |
metrics are OK
put_row_f (Begins at: 162 Ends at: 165)
LOC:          |       4 |       |      OK |
metrics are OK
put_row_d (Begins at: 167 Ends at: 170)
LOC:          |       4 |       |      OK |
metrics are OK
get_buf_c (Begins at: 173 Ends at: 176)
LOC:          |       4 |       |      OK |
metrics are OK
get_buf_f (Begins at: 178 Ends at: 181)
LOC:          |       4 |       |      OK |
metrics are OK
get_buf_d (Begins at: 183 Ends at: 186)
LOC:          |       4 |       |      OK |
metrics are OK
set_min_c (Begins at: 189 Ends at: 189)
LOC:          |       1 |       |      OK |
metrics are OK
set_min_f (Begins at: 190 Ends at: 190)
LOC:          |       1 |       |      OK |
metrics are OK
set_min_d (Begins at: 191 Ends at: 191)
LOC:          |       1 |       |      OK |
metrics are OK
set_max_c (Begins at: 194 Ends at: 194)
LOC:          |       1 |       |      OK |
metrics are OK
set_max_f (Begins at: 195 Ends at: 195)
LOC:          |       1 |       |      OK |
metrics are OK
set_max_d (Begins at: 196 Ends at: 196)
LOC:          |       1 |       |      OK |
metrics are OK
diff_c (Begins at: 199 Ends at: 199)
LOC:          |       1 |       |      OK |
metrics are OK
diff_f (Begins at: 200 Ends at: 200)
LOC:          |       1 |       |      OK |
metrics are OK
diff_d (Begins at: 201 Ends at: 201)
LOC:          |       1 |       |      OK |
metrics are OK
sum_c (Begins at: 204 Ends at: 204)
LOC:          |       1 |       |      OK |
metrics are OK
sum_f (Begins at: 205 Ends at: 205)
LOC:          |       1 |       |      OK |
metrics are OK
sum_d (Begins at: 206 Ends at: 206)
LOC:          |       1 |       |      OK |
metrics are OK
quot_c (Begins at: 209 Ends at: 209)
LOC:          |       1 |       |      OK |
metrics are OK
quot_f (Begins at: 210 Ends at: 210)
LOC:          |       1 |       |      OK |
metrics are OK
quot_d (Begins at: 211 Ends at: 211)
LOC:          |       1 |       |      OK |
metrics are OK
prod_c (Begins at: 214 Ends at: 214)
LOC:          |       1 |       |      OK |
metrics are OK
prod_f (Begins at: 215 Ends at: 215)
LOC:          |       1 |       |      OK |
metrics are OK
prod_d (Begins at: 216 Ends at: 216)
LOC:          |       1 |       |      OK |
metrics are OK
slope_c (Begins at: 220 Ends at: 232)
CalledNBR:    |       2 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
slope_f (Begins at: 234 Ends at: 246)
LOC:          |      13 |       |      OK |
metrics are OK
slope_d (Begins at: 248 Ends at: 260)
LOC:          |      13 |       |      OK |
metrics are OK
advance_band3 (Begins at: 264 Ends at: 276)
LOC:          |      13 |       |      OK |
metrics are OK
retreat_band3 (Begins at: 280 Ends at: 296)
LOC:          |      17 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  retreat_band3
In raster/r.fill.dir/tinf.c clones of  retreat_band3 are:
	raster/r.drain/tinf.c  retreat_band3
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
