[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.rectify/write.c |1 clones ( write.c write.c )| 0 monsters | 0 warnings
Wed Dec 13 10:02:42 EST 2006
Hello markus,
ANALYSIS
imagery/i.rectify/write.c functions
write_matrix (Begins at: 13 Ends at: 40)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
write_map (Begins at: 42 Ends at: 83)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  write_map
In imagery/i.rectify/write.c clones of  write_map are:
	imagery/i.ortho.photo/photo.rectify/write.c  write_map
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
