[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.out.ascii/main.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 10:02:43 EST 2006
Hello markus,
ANALYSIS
raster/r.out.ascii/main.c functions
main (Begins at: 29 Ends at: 207)
Complexity:   |      23 |     * |         |
CalledNBR:    |      52 |     * |         |
LOC:          |     179 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
