[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/color_look.c |no clones | 1 monsters | 5 warnings
Wed Dec 13 10:37:30 EST 2006
Hello markus,
ANALYSIS
lib/gis/color_look.c functions
G_lookup_colors (Begins at: 38 Ends at: 76)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       1 |       |      OK |
LOC:          |      39 |       |      OK |
at least 1 values are close to an outlier please consider revising code
G_lookup_c_raster_colors (Begins at: 78 Ends at: 118)
CalledNBR:    |       4 |       |      OK |
LOC:          |      41 |       |      OK |
G_lookup_raster_colors (Begins at: 120 Ends at: 158)
ParamNBR:     |       8 |    ** | Warning |
LOC:          |      39 |       |      OK |
G_lookup_f_raster_colors (Begins at: 160 Ends at: 193)
LOC:          |      34 |       |      OK |
G_lookup_d_raster_colors (Begins at: 195 Ends at: 210)
LOC:          |      16 |       |      OK |
less_or_equal (Begins at: 213 Ends at: 218)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
less (Begins at: 220 Ends at: 225)
LOC:          |       6 |       |      OK |
metrics are OK
G__lookup_colors (Begins at: 228 Ends at: 455)
Complexity:   |      29 |    ** | Warning |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      11 |       |      OK |
LOC:          |     228 |    ** | Warning |
1 metric are OUT OF RANGE!
G__interpolate_color_rule (Begins at: 457 Ends at: 481)
ParamNBR:     |       5 |     * |         |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
