[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/history.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 10:37:31 EST 2006
Hello markus,
ANALYSIS
lib/gis/history.c functions
G_read_history (Begins at: 74 Ends at: 153)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
G_write_history (Begins at: 155 Ends at: 204)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
G_short_history (Begins at: 206 Ends at: 259)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
G_command_history (Begins at: 261 Ends at: 301)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
