[GRASS-QA] GRASS QA: markus |
./grass6/lib/rst/interp_float/resout2d.c |no clones | 4
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 10:37:31 EST 2006
Hello markus,
ANALYSIS
lib/rst/interp_float/resout2d.c functions
IL_resample_output_2d (Begins at: 27 Ends at: 593)
Complexity: | 70 | *** | MONSTER |
ParamNBR: | 18 | *** | MONSTER |
CalledNBR: | 154 | *** | MONSTER |
LOC: | 567 | *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
