[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/ps_outline.c |4
clones ( alloc.c cats.c color_read.c find_cell.c get_row.c
opencell.c range.c ps_outline.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 10:37:31 EST 2006
Hello markus,
ANALYSIS
ps/ps.map/ps_outline.c functions
ps_outline (Begins at: 38 Ends at: 60)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 23 | | OK |
metrics are OK
read_outline (Begins at: 72 Ends at: 113)
Complexity: | 8 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 42 | | OK |
metrics are OK
draw_outline (Begins at: 119 Ends at: 153)
CalledNBR: | 14 | | OK |
LOC: | 35 | | OK |
metrics are OK
draw_boundaries (Begins at: 157 Ends at: 163)
CalledNBR: | 4 | | OK |
LOC: | 7 | | OK |
metrics are OK
read_next (Begins at: 167 Ends at: 175)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
o_alloc_bufs (Begins at: 180 Ends at: 186)
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
draw_top (Begins at: 189 Ends at: 203)
Complexity: | 2 | | OK |
LOC: | 15 | | OK |
metrics are OK
draw_rite (Begins at: 206 Ends at: 220)
LOC: | 15 | | OK |
metrics are OK
draw_left (Begins at: 223 Ends at: 237)
LOC: | 15 | | OK |
metrics are OK
draw_bot (Begins at: 240 Ends at: 254)
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
draw_bot draw_left draw_rite draw_top
In ps/ps.map/ps_outline.c clones of draw_rite are:
ps/ps.map/ps_outline.c draw_bot
ps/ps.map/ps_outline.c draw_left
ps/ps.map/ps_outline.c draw_top
In ps/ps.map/ps_outline.c clones of draw_left are:
ps/ps.map/ps_outline.c draw_rite
In ps/ps.map/ps_outline.c clones of draw_top are:
In ps/ps.map/ps_outline.c clones of draw_bot are:
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
