[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.out.v5d/main.c |no clones | 0 monsters | 0 warnings
Wed Dec 13 10:37:32 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.out.v5d/main.c functions
fatalError (Begins at: 48 Ends at: 56)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
setParams (Begins at: 61 Ends at: 84)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
getParams (Begins at: 89 Ends at: 92)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
convert (Begins at: 99 Ends at: 267)
Complexity:   |      10 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      21 |       |      OK |
LOC:          |     169 |     * |         |
metrics are OK
main (Begins at: 274 Ends at: 328)
Complexity:   |       5 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
