[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/window_map.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 10:37:31 EST 2006
Hello markus,
ANALYSIS
lib/gis/window_map.c functions
G__create_window_mapping (Begins at: 31 Ends at: 128)
Complexity: | 12 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 98 | | OK |
metrics are OK
G_northing_to_row (Begins at: 130 Ends at: 147)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
G_adjust_east_longitude (Begins at: 149 Ends at: 172)
Complexity: | 3 | | OK |
LOC: | 24 | | OK |
metrics are OK
G_adjust_easting (Begins at: 174 Ends at: 184)
CalledNBR: | 1 | | OK |
LOC: | 11 | | OK |
metrics are OK
G_easting_to_col (Begins at: 186 Ends at: 216)
LOC: | 31 | | OK |
metrics are OK
G_row_to_northing (Begins at: 218 Ends at: 238)
LOC: | 21 | | OK |
metrics are OK
G_col_to_easting (Begins at: 240 Ends at: 253)
LOC: | 14 | | OK |
metrics are OK
G_window_rows (Begins at: 255 Ends at: 287)
ParamNBR: | 0 | | OK |
LOC: | 33 | | OK |
metrics are OK
G_window_cols (Begins at: 289 Ends at: 294)
LOC: | 6 | | OK |
metrics are OK
G__init_window (Begins at: 296 Ends at: 312)
Complexity: | 2 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_row_repeat_nomask (Begins at: 314 Ends at: 343)
Complexity: | 5 | | OK |
LOC: | 30 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
