[GRASS-QA] GRASS QA: markus | ./grass6/lib/rst/interp_float/output2d.c |no clones | 4 monsters | 0 warnings
Wed Dec 13 11:41:49 EST 2006
Hello markus,
ANALYSIS
lib/rst/interp_float/output2d.c functions
IL_output_2d (Begins at: 27 Ends at: 706)
Complexity:   |      81 |   *** | MONSTER |
ParamNBR:     |      18 |   *** | MONSTER |
CalledNBR:    |     187 |   *** | MONSTER |
LOC:          |     680 |   *** | MONSTER |
4 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
