[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/build_nat.c |no clones | 0 monsters | 2 warnings
Wed Dec 13 11:53:44 EST 2006
Hello markus,
ANALYSIS
lib/vector/Vlib/build_nat.c functions
Vect_build_line_area (Begins at: 35 Ends at: 107)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      73 |       |      OK |
metrics are OK
Vect_isle_find_area (Begins at: 116 Ends at: 224)
Complexity:   |      10 |       |      OK |
LOC:          |     109 |       |      OK |
metrics are OK
Vect_attach_isle (Begins at: 233 Ends at: 257)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Vect_attach_isles (Begins at: 266 Ends at: 290)
Complexity:   |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Vect_attach_centroids (Begins at: 299 Ends at: 377)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
Vect_build_nat (Begins at: 386 Ends at: 607)
Complexity:   |      33 |    ** | Warning |
CalledNBR:    |      54 |     * |         |
LOC:          |     222 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-13 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
