[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/ps_vpoints.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Dec 13 12:03:54 EST 2006
Hello markus,
ANALYSIS
ps/ps.map/ps_vpoints.c functions
PS_vpoints_plot (Begins at: 18 Ends at: 214)
Complexity: | 33 | ** | Warning |
ParamNBR: | 3 | | OK |
CalledNBR: | 57 | * | |
LOC: | 197 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-12-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
